Engine information
  • Engine information
    I have a 1961 studebaker lark name plate says 61S-J6 887. The engine in the car though is a V-8. Which according to the name plate should be a v-6. The engine number on the is PI2038 with a stromberg carb model ww 6-127. Also has a delco remy distributor 1110839 4m7. I was wondering if any one can give me more information about the engine since i dont think it is original by everything i have seen or read in online and in print. Any help would be greatly appreciated.
    While I don't know the numbering system...there was and is no Studebaker V-6's..!
    At least not on purpose.
      I just looked in the door and the serial number on the door said 61S-I6009
        61S J6
        887
        ...is the body tag. The serial number plate is on the driver's side A pillar.
        61S= 1961 six cylinder
        J=2 door hardtop
        6=trim level
        887=sequence in which the body was welded up (887th body made...no relation to the serial number of the car)
        The car was originally a 6 cylinder (straight 6...Studebaker did not make a V6)
        V8 engine numbers are here...
        http://www.studebakerdriversclub.com/V8EngineID.asp
        Yours looks to be a 289 out of a '55 President.
        It most likely has a V8 transmission also.
        Check the brakes and rear end. If they are still 6 cylinder items, you should upgrade to V8 items.
        Bellingham, WA
        Bellingham, WA
          your right i meant a inline 6. i am trying to help out my dad with this. Also looking for a replacement distributor for the car any suggestions?
            thank you for the information dick steinkamp.
              Dick S. - I am sure that you know that there is no such thing as "a 289 out of a '55 President." I didn't look the number up, but it is probably a 259 out of a 1955 (I don't know how you would know if it was a President or late Commander.) or it is a later 289.
              monte nc - what you post as an "I" in the engine number represents a 1 (one).
                Whoops...Yes, '55 was the only year that the P prefix indicated a 259...my bad. For all other years, the P prefix meant 289.
                If it was a 259 Commander, it would have a V prefix.
                Bellingham, WA
                Bellingham, WA
                  if it has a Delco dist. you might just want to have that one rebuilt rather than replace it. They are supposedly more durable than the later Prestolites.
                    Yes, Dick, now I guess that we are even <G>. I wasn't thinking that Studebaker used the V for both the 224 and the Commander 259 in 1955.
                      I did'nt think any 55 Commanders ever used the 259,but only the 224.the 259 only applied to the President.
                      Joseph R. Zeiger
                      Joseph R. Zeiger
                        Many of us have replaced these with new electronic distributors, available from many of our great SDC vendors.
                          The 259's were used in the 1955 Commanders as I rebuilt one a couple of years ago. Bud
                            Joseph R. Zeiger
                            Early 1955 Commanders used the 224. Mid-year a change was made that made 259s standard in 1955 Commanders. (1955 Presidents had 259s throughout the model year.)
                              I was looking at a 55' Speedster a while back and the engine Ser. # began with PC. The engine looked to be the original in that it had the 4 bolt valve covers, top mounted oil filter, engine color was a dark green I think and the overall patina suggested it might be the original. My question is, did they make any Speedsters or Speedster engines in Canada or was I just looking at a non-original engine such as a Canadian 289 (PC)?
                              Dean Croft
                              Roseburg,OR
                              CLEM DESEE
                              Dean
                              CLEM
