1962 Hawk 289
I want to install an oil pressure safety switch for an electronic fuel pump.
I don't think it would be attactive to install it in the line to the oil filter, near the water pump. I don't know where the oil line to the dash oil pressure guage is. Any help is appreciated.
I am replacing an electic fuel pump and want it safer than what the previous owner had. Also, he did not have a regulator. Will I need one for a Facet-Purolator Posi-Flo pump, FEP06SV 4.0-7.0 PSI, 32 GPH?
I'm replacing the pump because my mechanic said I needed it. The car seems to be starved for gas at higher speed (40 mph), but only sometimes. I've rebuilt the Stomberg www and the trouble started. If it ain't broke... (I wanted to fix a gasket leak). I've since cleaned it 3 more times, and was careful to set the float to specs.
The power for the currently installed fuel pump comes from the accessory power. I want to change it to power from the ignition coil. But I'm concerned that I may have problems if the power to the ignition coil is fed through a resistor, perhaps a "resistor wire." Is this a problem? The pump may draw several amps (4?) and there would be a voltage drop across the resistor. This may be a problem for the pump, and the ignition coil. How about the ignition coil fuse. Is there a fuse in the coil supply?
I've checked the shop manual for this, without help.
Your wise advice is appreciated.
Walt B
Walt B
