How many soft (freeze) plugs are there in a 289 engine block in a 1962 GT Hawk with FOM? This is not a riddle. Can the soft plugs be removed and replaced without removing the engine?
289 soft plugs
The starter needs to be removed to get to the one on the drivers rear one. It is best to use an expansion plug installation tool. Opinions vary, but I prefer the brass shallow cup style. And the block drain plugs should be removed and replaced also. They rust out, as they are steel from the factory.
63 Avanti R2, 4-Speed, 3.73 TT
Martinez, CA
I replaced my drain plugs with pet cocks........now very easy to drain block
Martinez, CA
1 1/2 in. Brass X (6) Pcs.
If you have the early non-full flow block '62 you also can use the Copper and brass bolt-in Dorman type also available at the above sources, like Matt Burnette very recently mentioned using, here in his '58 Commander.
StudeRichStudeRich
