Steering wheel nut
  • Steering wheel nut
    Can someone tell me the size of the large nut that holds the steering wheel. I have to remove the wheel so I can check the turn signal switch. The handle will not go in the down(left turn) position.
    John Ratliff
    1 1/4 I believe. That is what is on my 53 Starlight Coupe. Hope it helps. I would imagine they are the same.
    Bob
      Thanks a lot, Bob
      John Ratliff
        I think they're different on pre-57 and 57-up cars but I don't recall the sizes.
          Nate's right. Ran into this putting a '57 Hawk PS setup in my '53. The '57 and up is smaller. Don't know the sizes off hand either.
          Jeff in ND
          '53 Champion Hardtop
          Jeff in ND
            Bob
            Your right, Bob is 1 1/4 nut. Bought the socket today and will work on it Wed.
            Thanks
            John Ratliff
              Well, I got the steering wheel off this morning. The reason for pulling it was the turn signals would never return to neutral. Only manualy. Then the other day, when I was pulling out of the garage, the wheel seemed to hang up. A little tug on the wheel and every thing was okay. At least I thought it was. When I tried to push the turn signal down for a left turn it would not go down. Up or neutral but not down. After I got the wheel off I seen a bent up strip of metal stuck in the turn signal plate. It seems to be the lock plate. I cannot see how it was mounted. Can any one tell me what it mounts to and how. Also I need a new one if available. Part no#1310-04
              John Ratliff
