Took my '49 2R15 out for a drive yesterday morning (it's second one) and had a bit of a scare. On the way home, I noticed the oil pressure gage was down to about 5 PSI. My speed was around 35 and the outside air temperature was 90, the hottest it's been since the rebuild. The temperature gage, which has never gone over 170, was past the 170 mark, maybe 180 or 190. I'm using Shell Rotella T 15W40 oil and it's less than half a quart from being full. The radiator is full of 50-50 antifreeze. I let it sit for about three hours and restarted it The oil pressure was 15 at normal idle speed and 40 at a fast idle and the temperature gage was below 170, maybe 130 or so. Did the engine get hot and thin out the oil or did the oil pressure drop causing excess heat in the engine? When the air temperature was only getting up to the high 70s I could keep the oil pressure up in a safe range, even idling. Is it time for new gears in the oil pump? Maybe the oil thins out when it gets hot and the pump has a bit too much clearance? Or could this be a problem with the oil pressure relief valve sticking? (It was new when the engine was rebuilt in January.) The engine is the original Champ.
Rick
Kingman, AZ
"Leroy"
Rick
Kingman, AZ
"Leroy"
