'55 Commander engine smoking
  • '55 Commander engine smoking
    Today the '55 Commander exhibited much more smoking on the passenger side of the car than ever in the past since I've owned it. The exhaust manifold itself seems to have smoke emitting from it but there is no discernible oil leakage from the valve covers. There is a leak at the back, the rear seal I presume, but that's an oil leak and on the driver side. The smoke was enough I had to turn the garage celing fans on to dissipate it after less than a minute backing in. Could this be associated with the heat riser?
    '55 Commander
    '55 President
    \'55 Commander
    \'55 President
    I had a similar problem with my Land Cruiser. Turned out to be the felt crankshaft seal in the front timing cover. The car wouldn't smoke at home. When it got out on the highway and warmed up pretty good, the oil would get blown on the exhaust and look like the proverbial mosquito sprayer going down the highway. Of course, in the rear view mirror, it looked like it was coming from the exhaust. I finally converted it to the neoprene type seal and the problem was solved.
      Alright, thanks. I'll concentrate on that area first. Sure happened relatively fast.
      '55 Commander
      '55 President
      \'55 Commander
      \'55 President
