Diaphragm clutch?
  • Diaphragm clutch?
    Is it possible to run a GM diaghragm clutch in a Stude? Got a bum left knee and the diaphragm clutches are a tad easier on it.
    Analog man in a digital world.
    I've heard yes, but you have to clearance the heck out of the bellhousing. I tried to make it work on my '55 but even after aggressive clearancing it still hit. I'd wait for a response from someone who's actually got it to work... (I probably just didn't have the exact right one; I'd try to use the exact same part as someone who's successfully done the conversion.)
    Alternately, check with Fairborn, I know they have nice aftermarket "blowproof" bellhousings, those should work fine with no mods, but I'm not sure if they work with the stock clutch linkage - may only work with Chevy style.
      Thanks Nate, I can handle the Borg & Beck but I thought if there was an easy way to run the diaphragm I would, every little thing I can do to lessen the load on what's left of the cartilidge in there helps.
        The diaghragm clutch will fit the truck bellhousing. Tryed to use one in a car. Ground on the housing until there was a hole in it. Couldn't make it work Jim
          All I use are diaphragm clutches. I grind off the bumps inside, never had a problem. I use mustang clutches because I use ford transmissions, but i don't see why a chevy would be any different.
          Dan Giblin
          Cincinnati, OH
          Dan Giblin
          Cincinnati, OH
            how about adapeting a cable or hyd. clutch system everybody uses them to day so paarts would be no problem just making a bracket or two. or go to the junk yard and see if they have any cars or trucks with brackets attached and go from there. nothing is impossible just get an bigger hammer.
              Respectfully disagree. If the OEM Stude engine is being retained, the Stude mechanical clutch activating system is the strongest, best-engineered part of the car. The problem being discussed is not in the actuation system, but the change to diaphragm clutch cover hitting the inside of the bell housing. Not sure how the extra complication of hydraulics or cable would alleviate that.
              thnx, jack vines
                If you can find a good clutch house they will know the specs of the springs in the pressure plate. Ask them for a softer spring set. Probably won't be any good in trailering or fast getaways, but may help the knee.........
                  The issue with B&B clutches are they get harder to press the pedal down the closer it gets to the floor. Correct me if I'm wrong but they do not go past the center point when released like a dia will. I believe this is why the dia. clutch is almost effortless at the floor (disengaged position).
                  I would not go to hydraulic, seems it would be tons of effort for not much reward.
                  Dan Giblin
                  Cincinnati, OH
                  Dan Giblin
                  Cincinnati, OH
                    Grind off the bump put a Center/Force unit in it and forget it. Have a dual friction unit in both my R3 and the Twin. Ten years no problems.
                      Well I found a heck of a buy right after I posted this on a new 10" B & B pressure plate and disc so I guess I'll just double up on the Glucosimin the nights before I drive it and Arthiritis Strength Tylenol the nights after. Sacrifices must be made when you're a CASO!
                        I'm with Karl on this. Years ago I bought a clutch assembly from NAPA in Torrance for my 66. Didnt notice the throw-out bearing was from China. Blew apart in a couple of months. Doubting the intergrity of the rest of the assembly, I replaced it all with a Centerforce unit. Not only is the clutch easier & smoother, but it grabs like there is no tomorrow when needed! There is a time & place for everything, including when & when not to be a CASO.
                        60 Lark convertible
                        61 Champ
                        62 Daytona convertible
                        63 G.T. R-2,4 speed
                        63 Avanti (2)
                        66 Daytona Sport Sedan
                        60 Lark convertible V-8 auto
                        61 Champ 1/2 ton 4 speed
                        62 Champ 3/4 ton auto
                        63 G.T. Hawk R-2,4 speed
                        63 Avanti (2) R-1 auto
                        64 Zip Van
                        66 Cruiser V-8 auto
                          Well although it's not a factory Studebaker clutch it IS Genuine GM made in the good ol' US of A. If you do your homework on cross referencing parts, know EXACTLY what you are looking for and are willing to patrol the "backwaters" of Ebay there are deals to be found on quality parts.
