Tire balance with Equal?
  • Tire balance with Equal?
    I've been using Equal in the tires of the truck fleet at work. Anyone used it in passenger tires?
    I'm about to mount the new tires on Desiree.
    Pros and Cons?
    Brad Johnson
    My wife uses Equal in he coffee.
    She's fairly well balanced.
    (But she shimmy's a bit if steered the right way[])
    (Stemco has been selling that stuff for IMI for years)
    Pros and Cons?
      Geez Jeff, you just crack me up!
      Don't know the name Equal, other than for a sugar substitute.
      My neighbor/friend across the alley is a trucker and uses some kind of 'beads' in his tires for balancing. Been doing it for years and is totally happy with the system. Is that what Equal is?
      '50 Champion, 1 family owner
        quote:Is that what Equal is?
        Basically, yes; more like a powder than beads. Drop a bag in the tire before mounting. The bag breaks apart and the powder distributes itself everytime the tire rotates. No exterior wheel weights. It must be kept dry and requires replacement of the valve stem.
        Seems to work well in our trucks. I was just wondering if anyone has used it in passenger cars.
          I don't know about "Equal," but I have used this stuff. The Hurst "Cheater Slicks" on my '56 are recaps and you know how out of balance they can be--they have to be static "bubble" balanced and so I decided to go with this stuff. Haven't really been at high speed yet in the '56, but a buddy of mine with an old Triumph swears by it.
          http://www.innovativebalancing.com/s...htm#AppInstall
            Here you go....
            http://www.imiproducts.com/equal/tire-balancer.aspx
            For a bunch of feedback, etc...
            Google 'Equal Tire Balancer'
            Lot's of hits...
              Try Road Force Balancing (I'm assuming radial tires). After having one car done the difference was so noticeable I took two more over to the shop the same day. The Avanti's next if I can keep it off jackstands long enough. It doesn't cost much more than std. electronic balancing either.
              ErnieR
              On its way to a 15.097 Spring 2006.
