Cobra Brake brackets first article set from CNC
  • Cobra Brake brackets first article set from CNC
    Edit per new picture location : 12/1/08
    I got the first article set of brackets from the CNC machinist last week, I
    removed some material, and decided on a name/logo/position. I have
    considered black anodize, but thats still in the air right now. I have to put
    them on the Avanti and confirm fitment, and I can give the green light for
    the CNC guy to make the remaining 10 sets. The logo will be engraved
    into the leading edge flat of the bracket, which can be seen with the wheel
    turned to full lock.
    I will add to this thread the install of the first article set, when I get to it. I
    think they came out very nice :
    Tom
    Looks very nice! Can't wait for my set!
    53commander HDTP
    53 Champion HDTP
    61 Cursed Purple Hawk
    64 Champ long bed V8
    53 Hudson Super Wasp Coupe
      Looks good Tom! Good to hear from you again! Hope you had a great Christmas!
        Well done! Waiting on my set also. Very Happy New Year to all.
          Thanks for the positive feedback guys ....
          I think its worth hitting on a few things brought up on the Racing
          Studebakers forum. The calipers I had on the Avanti originally were
          single piston GT ones, & fit inside a 15 inch wheel. Unfortunately,
          offsets/wheel cross sections have changed and the GT caliper (& the
          Cobra) sit out further toward the wheel then the Stude did. Even thou
          the diameter of the wheel will clear, I TRIED (and posted the info &
          included in my Avanti magazine article) the stock Stude wheel, and it
          will not clear the caliper. Regardless of which (GT or Cobra) setup
          is used, the wheels WILL have to be changed. If the GT setup is used,
          & and a 2 piston caliper is wanted, the 03/04 GT uses a PBR 2 piston
          caliper for the smaller 11 inch rotor. As previously mentioned, this
          should fit my bracket, though its not confirmed since I dont have one
          laying around. Any Baer, Wilwood, etc setup should also fit my bracket
          (though not confirmed). If any of you want to try these - contact me.
          The setup just mimics the factory 94-04 SN95 Mustang caliper mount to
          hub relationship. It then requires that you use wheels designed for
          94- 04 Fords (but still clear the Stude suspension), way back in the
          first article it was stated that Crown Victoria wheels are steel and
          15". These will fit the GT setup. If someone wants the cheaper single
          piston GT caliper, then the half circle cutout is required, & the CNC
          guy is setup to modify them accordingly.
          I'm open to suggestions, constructive critizism, & creative feedback.
          Those on the current list will give the "best" feedback, as they are
          actually mounting them on their cars. This will help me to find out
          how close Stude kept their tolerances.
          No official price has been posted. Also, keep in mind guys, this setup
          will fit ALL Studebaker front suspensions from 1952 to 1966.
          Gotcha, are you receiving the update emails? I hope you are on the
          current list - I dont want to forget anyone![:I]
          Tom
            Tom...gotcha is Bob Doty. I receive emails from you under rwdoty@msn.com. I will be using 17 inch aftermarket wheels on my '53. Keep me posted. Thanks.
              Ah! I checked and I got yah 'gotcha'. Just making sure.
              If there is anyone that was interested, and is has not received a few
              updates in recent months by email, then email me so I can add you!
              Tom
                I had the CNC shop make 3 more sets, two are spoken for. Just FYI.
                Tom
