On the 259 engine in my '63 Lark there is oil leaking from the top passenger side of the engine. This appears to be an oil line that runs to the oil pressure gauge. The valve cover is definitely not leaking. Does anyone know what the part number for the short rubber/steel? line that runs between the block and the tube that runs through the firewall? Is the line threaded into the block or pressed in?
Oil Leak on Top
Threaded. I don't have the part number handy but this hose is readily available from most Stude vendors and is one that should be replaced from time to time as a matter of maintenance. If yours is leaking REPLACE IT NOW ! If it has sudden failure while driving, which it is prone to do, you won't make it to the next traffic light.[V]
The upside is, your engine compartment will be liberally rust-proofed.[
Brad Johnson,
'56 Sky Hawk in process
530096 available from virtually every Stude parts vendor since the same hose covers many years.
This hose should be replaced as often as flex brake lines (every 5 years or so). If the hose brakes at highway speeds, it's probable that the crankcase will empty and the engine will seize before you can react.
Bellingham, WA
Bellingham, WA
