alt.vs. gen
  • alt.vs. gen
    when did studebaker starting using alts?1962 or 1963
    if i convert to a one wire alt do i need a voltage reg?
    what brand did stude use? ford,gm.chrysler?
    does the studes use horn relays or any other relays?
    Depends on what model you have, Hawk/Lark use a Honda alt, Avanti R1
    use a GM alt, and I dont recall the R2 swap info ... look here :
    http://www.studebaker-info.org/rjtechx3.html
    Tom
    '63 Avanti, zinc plated drilled & slotted 03 Mustang Cobra 13" front disc/98 GT rear brakes, 03 Cobra 17" wheels, GM alt, 97 Z28 leather seats, soon: TKO 5-spd, Ported heads w/SST full flow valves, 'R3' 276 cam, Edelbrock AFB Carb, GM HEI distributor, 8.8mm plug wires
      you can go to a one wire easily and it just runs a large wire from your battery positive to battery post on alt. or you can save some money and hook a normal gm alt. run a heavy wire from you battery postive to your battery term of your alt, then on your plug into your alt you have a F terminal Field tie that into your battery terminal of your alt too, the on your Regulator term marked R run another wire that is only hot when the key is in the run position. will work great and save you 50 bucks. and if you ever have an issue you can get another at any parts store.
      Erin Hays
      "From Stuck and Rusty to Slick steel and sex appeal"
      RZRECTD
      1961 Hawk
      1962 Lark
      1963 Wagonaire
        http://www.madelectrical.com/electri...hreewire.shtml
        http://www.madelectrical.com/catalog/alt-1.shtml
          FYI:
          Mark of MAD indeed know his stuff: we used to work together at a repair shop in SoCal 25 years ago.
