dual master cylinder
  • dual master cylinder
    Does anyone have any coments or instuctions on changing the original Avanti single chamber master cylinder to a dual chamber? Can you keep the original booster? Just trying to give new life to an old ride and go down memory lane.
    Use a Chrysler, (see April 2001 Turning Wheels for the correct number) You will need to adjust the linkage between the booster and the M/C, Get 2 2/16" brake lines, a 3/16" flaired union, and a plug for the T fitting under the M/C on the frame. The plug MUST be for a flare fitting. Yes, use the original booster.
    Jim
    their Memorials!
      http://www.studebaker-info.org/rjtechx3.html
      Tom
      '63 Avanti, zinc plated drilled & slotted 03 Mustang Cobra 13" front disc/98 GT rear brakes, 03 Cobra 17" wheels, GM alt, 97 Z28 leather seats, soon: TKO 5-spd, Ported heads w/SST full flow valves, 'R3' 276 cam, Edelbrock AFB Carb, GM HEI distributor, 8.8mm plug wires
