camshafts
  • camshafts
    what were the spec's for the r-series cam? or did they use the same cam? can anyone give me the;lift;duration;lobe centers;for each of the r-engines? or were can i find this info? right now it looks like an engine swap(have an 374 packard) would it fit in a 63 lark? and does anyone custom grind stude cams? i'm planning a course of action when i pick up my 63 lark 2-door. have not desided which way i'm going. need more info. thanks
    Iskenderian will grind a cam for your engine. They have what they call an E4 or an ST5 grind. I have an ST5 cam in my Avanti and it works really well though the idle isn't the smoothest, but the exhaust sounds good. The E4 will give you a smoother idle and I believe is better suited for an engine with stock compression and higher rear end gear ratio. You will have to send a regrindable core to them as new cam blanks are no longer available. Bud
      Get ahold of Phil at "Fairborn Studebaker".
      He should have all the info you desire...including cams, ready to go.
        Here are some links to some R series data. Sorry I don't have it in better resolution, but it should be readable.
        http://www.studegarage.com/images/ot...R4_specs_1.jpg
        http://www.studegarage.com/images/ot...R4_specs_2.jpg
        [img=left]http://www.studegarage.com/images/indy/gary_indycar25_vvsm.jpg[/img=left] Gary Ash
        Dartmouth, Mass.
        '48 M5
        '65 Wagonaire Commander
        '63 Wagonaire Standard
        Gary Ash
        Dartmouth, Mass.
        ’41 Commander Land Cruiser
        '48 M5
          There are a few notes here..
          http://www.studebaker-info.org/text3/rseriescamspec.txt
          Bob Johnstone
          64 GT Hawk
          55 President State Sedan
          70 Avanti (R3)
          64 GT Hawk (K7)
          1970 Avanti (R3)
            FWIW, for anything approaching street use with stock heads, the standard R1 cam can't be beat. After the first $2,000 in pro head work and a custom intake, then big bucks cams earn their money.
            thnx, jack vines
              Here are the details:
              Dan White
              64 R1 GT
              64 R2 GT
              Dan White
              64 R1 GT
              64 R2 GT
              58 C Cab
              57 Broadmoor (Marvin)
