Bolt patterns for wheels on a 3/4 ton truck
  • Bolt patterns for wheels on a 3/4 ton truck
    I just got 2 wheels and new-ish bias ply tires.(most likely old tires that have been sitting for a while in a garage) The rims look darn near new.
    I trying to see if they will fit a stude truck. They are 6 bolt 16" not sure of size for the bolt pattern or hub hole as yet.
    What would the right size be?
    Thanks guys!
    I have a 1950 4 door Commander a 51 land cruiser And a 52 Champion
    I'll Tattoo you anytime!
    And you can find me at....
    New Shop Name Same tattoo shop
    Crazy Lady Ink
    Shakopee Mn.
    952-445-3281
    27 years in the tattooing biz
    Stude 1/2 ton trucks were 5 x5 bolt pattern and the 3/4 ton trucks were an 8 bolt pattern (C-Cab and T-Cab models). The only trucks I have seen 16" x 6 bolt wheels on were 1 ton models, but that is an unusual size as most 1 tonners have 17" or 17.5" wheels (some even have 19" wheels).
    <h5>Mark
    '57 Transtar Deluxe
    Vancouver Island
    The NW Overdrive Tour in Parksville, BC
    May 23 & 24, 2009; check it out at -
    http://sdcvi.shawwebspace.ca/
    </h5>
    Mark Hayden
    '66 Commander
    Zone Coordinator
    Pacific Can-Am Zone
      Bolt pattern for Stude 1tons with six lug are the Budd 16 x 5.5 F or Kelsey-Hayes 16 x 6.50 H with 7 1/4 inch bolt circle with 5 9/16th pilot hole for the Budd and 5 11/16 for the Kelsey Hays.
      3/4 ton trucks prior to 1955 used similiar wheels .
      After 1955 the eight lug wheel became more common but the "Budd" style wheel was still optional. For 1963-64 E13's(the 1 tons) there were one standard wheel and six optional wheels up to 19.5 x 5.25 tubeless tire rim.
      My 5E13 and the parts truck axles I got with it are 16 x6 , six lug.
      3E38
      4E2
      4E28
      5E13
      7E7
      8E7
      8E12
      8E28
      59 Lark
      etc
        Edsel, if those are non-split Rim (one piece) they are extremely hard to find, my 7E-13 needs seven of them!
          Thanks for the info Charlie... learn something new every day!
          <h5>Mark
          '57 Transtar Deluxe
          Vancouver Island
          </h5>
          Mark Hayden
          '66 Commander
          Zone Coordinator
          Pacific Can-Am Zone
            I thought my great big huge 49 that I used to have had Five lug huge pattern. It had rear duals and a two speed axle.
              The '49-early'56 3/4t had 6-bolt 16" wheels and the 1ton and up had 5-bolt l7" wheels - go figure!
              thnx, jack vines
                Well I looked at the tire size as I was leaving the house today they are 16 x 6.50 H On the tires. They Might be the Kelsey-Hayes I'll measure them when I get home and Post a pic and Measurements.
                If they are, what would be a fair price? Also who needs them?
                Crazy Lady Ink
                Shakopee Mn.
                952-445-3281
                  They are not split rims, One piece I believe tubed. I'll post measurements later today.
                  Crazy Lady Ink
                  Shakopee Mn.
                  952-445-3281
                    Here is the link for the pictures.
                    Now Did I measure these right?
                    Lug holes are 4 1/2
                    HUb is 3 1/2" or 3 5/8"
                    Rim is 16 "
                    Tire size is 6.50-16
                    Does this help?
                    http://www.facebook.com/album.php?ai...9&l=39549aac47
                    Crazy Lady Ink
                    Shakopee Mn.
                    952-445-3281
                      New one to me. I've never seen that wheel on a Stude truck.
                      thnx, jack vines.
                        47-UP CHEVY/GMC 1/2 ton used these I believe
                        54 15G coupe future Bonneville car 200 mph
                        63 Lark Custom 2D R1 4speed 1of1 bench seat
                        CUSTOM R1
                        51 2r11 truck 289 4 2bbl carbs 5 speed
                        59 Chassis Research dragster 347 Pontiac powered
                          Some GM trucks used a 5 lug pattern but to me those wheels do look pretty GM-ish. Some years the lug pattern was different between 2WD and 4WD (why? who knows.)
                            Well If that is the consensus. They are GM Rims.
                            Well I'll sell them as such.
                            THanks for the input.
                            Crazy Lady Ink
                            Shakopee Mn.
                            952-445-3281
