drip moulding 63 gt
  • drip moulding 63 gt
    is there a tool that will remove the stainless drip moulding without messing it up?
    No, there isn't. It's been discussed before, that it's all but impossible to remove those without damaging them. Unless there is known rust or some serious issue for which they absolutelty must be removed, it is best to leave them on there and carefully mask them off, even if every other piece of trim and glass have been removed. BP
    Ayn Rand:
      Oh yeah! leave well enough alone unless yours are seriously damaged. jimmijim
        Now those are a great item for someone to reproduce.
        Tom - Mulberry, FL
        1964 Studebaker Daytona - 289 4V, 4-Speed (Cost To Date: $2125.60)
        Tom - Bradenton, FL
          re drip moulding. rust is the problem, the previous owner filled the drip mounding up with some caulk on top of the rust and it has festered up. I have removed dripomounding before by hand on a 57 hawk and did not want to do it again if i can avoid it. thanks
            That channel is supposed to have seam sealer in it. The factory did it. You may be able to dig out the old seam sealer, kill the rust, and replace the seam sealer with new without removing the drip rail.
            Bellingham, WA
            Bellingham, WA
              As Dick says. jimmijim
