need some information
  • need some information
    I have a 51` studebaker with serial#8207I72, Body tag# HF-5 3709, The engine#535601. Can some one please tell me if this is a champ. or a comm. and is this a true V-8 car.
    Any Info. will be greatly appreciated. thanks
    The serial number indicates that this is a Commander built in South Bend.
    HF5 shows that this is Commander State sedan and the 3709 is the tub number for the shell. V-8's were available in '51 with engine numbers starting at 101 and up. There were 21,134 of these models built in all plants. the only way to varify if this is the original engine for this car is to get a copy of the build sheet from the Studebaker NAtional Museum. Cost is around $25. Most likely this is an original combination.
    Tom - Lakeland, FL
    1964 Studebaker Daytona
    Michigan Speed - www.michiganspeed.com
    Club Hot Rod - www.clubhotrod.com
    LS1 Tech - www.ls1tech.com
    Tom - Bradenton, FL
      Thanks for the info. Swifster
        Is the engine a 232 V-8.
        Thanks
          The 535601 number you found is an engine block casting number used from 1955 to mid-1962. Try to find a STAMPED engine number at the front of the block on the oil fill tube from the number you found. That number will tell us what year and cubic inch the engine is (unless someone bored, stroked, etc.)
          [img] http://home.comcast.net/~jdwain/63.63.jpg [/img]
          Dwain G.
            The stamped # is V542880
              Looks like a 1962 259.
              http://www.studebakerdriversclub.com/tech_v8data.asp
              Bellingham, WA
              Bellingham, WA
                The 51 engine would have the number stamped at the back of the block, to the passenger side of the distributor.
                  Thank all of you for the info.
