Anybody in NC got a gas tank for 66 Cruiser?
  • Anybody in NC got a gas tank for 66 Cruiser?
    While mine's not leaking yet, my mechanic insists I need a new one because of serious rust. I just wanted the vent tube opened up and debris cleaned out of the bottom of the tank. But, it's already off the car. The problem started with air being trapped in it and not being able to fill it with gas or getting steady fuel flow to the 2V carb on the 283 engine.
    edp/NC
    \'63 Avanti
    \'66 Commander
    What part of NC are you in? If that tank doesnt leak or isnt crushed I have seen very few that cant be boiled and sealed. Depending on how bad it is a radiator shop could be your friend. If that doesnt work fill the tank full with 8 parts water and 1 part muratic acid then seal it with a good tank sealer. I prefer the Kreme brand myself but there are others reputed to be as good. Most body supply houses and better motorcycle shops carry some type,though m/c shops will usually have to order the larger size you will need. Steve
      Check with SASCO. You may find a new one at a good price.
        edpjr,You should talk to the guys at Gemco here locally. I have seen some tanks that they made and plan to take the tank out of my 55 truck to them next week.They are on 321A in Joyceton.Your car looks good.Did you find it here locally?I work in the parts dept at the local Chev/Buick/Pontiac/gmc dealer. Good day
        thom
        thom
          I think that the only tanks that Sasco has left are for the wagons.
          You can move the filler neck to fit your car.
          Bob
            Thanks for the info! The car came from Virginia. It's got rusted rocker panels (bad) and front fenders. We're gonna order replacement rockers, but my brother says can fix the fenders.
            thom
            edp/NC
            \'63 Avanti
            \'66 Commander
              That is correct. What SASCO has in stock fits 59-63, but they say it can be modified to fit 64-66 by relocating the filler tube.
              Bob
              edp/NC
              \'63 Avanti
              \'66 Commander
                They got the tank off and said it's done for. I was skeptical too. Supposedly, they found us a replacement from a salvage yard in Raleigh. So we may be rolling again by the end of the week and getting ready to address the body rust issues. Thanks!
                edp/NC
                \'63 Avanti
                \'66 Commander
                  SASCO also has stacks of '64-66 front fenders.
                  Matthew Burnette
                  Hazlehurst, GA
                    Is there another 'Brand X' tank that would fit a 1966 Stude sedan? I was told an early 1950's Ford Customline repro may............
                      I've got a beautiful gas tank for your car, but I'm in California. What to do.... what to do.....
                      sals54
                      sals54
                        I'll throw my 2 cents worth in here. Having been through rust and scale in the gas tank of my 66 Daytona, I can empathize with your delima. Mine wasn't pinholed from rust so I did an econo clean and seal. If ya have to replace the tank, I'd rather move a fill tube as opposed to a salvage yard tank that may be full of gremlins. Ya may wind up with similar circumstances. I'd grit my teeth and buy da NOS tank and move the fill tube and it's already embossed for the sedan location.
                        Kim
                          Thanks! I did buy new fenders from SASCO.
                          Matthew Burnette
                          Hazlehurst, GA
                          edp/NC
                          \'63 Avanti
                          \'66 Commander
