Avanti Fuel Sending Unit
  • Avanti Fuel Sending Unit
    Does anyone have an interchange for the fuel sending unit used on the Avanti? I know that they are available from a couple of our favorite vendors, but the price has jumped to $85. Call me a CASO, but that's a bit much for a sending unit!
    Jim Bradley
    Lewistown PA
    '78 Avanti II
    Jim Bradley
    Lake Monticello, VA
    '78 Avanti II
    That's about as cheap as you'll find.
    JDP/Maryland
    JDP Maryland
      I installed a fuel sending unit in my 62 champ pickup from sumitt same ohm rating as studebaker,has
      a adjustable arm that can be cut to size.Let me know and i can look up the part number.It might
      work in the Avanti.On my 63 Avanti if the fuel sender goes i am going to get one.
      Lenny
      Atlanta Ga.
        It can cost a lot more if you run out of fuel.
          You can get a sending unit from Auto Meter for the 240/33 ohm gauge used by an Avanti It comes with instructions on how to measure and set it properly for an individual car. It's not quite the drop-in procedure as the proper sender is but is a pretty simple install. It costs $31.88 from Summit Racing <http://store.summitracing.com/partde...toview=sku>. The Auto Meter part number is 3262. The cost from Jegs is probably about the same.
            Thanks, all.
            I guess that the fact that the sending unit had jumped from $50 to $85 in price sort of ticked me off. This unit is a wiper resistor only, without the fuel pick-up or strainer, so $50 was really an outside figure for its value. The $31 unit from Summit is probably more realistic.
            Anyhow, I decided to pull the existing sending unit and see what was going on. I found that the wiper was somewhat corroded and not making good contact. I drilled out the rivets and pulled the wiper. I cleaned it and adjusted the tension of the arm. After re-assembly, I installed it and it seems to be functioning OK.
            Jim Bradley
            Lewistown PA
            '78 Avanti II
            Jim Bradley
            Lake Monticello, VA
            '78 Avanti II
              Seeing as how the one from Summit Racing is a Stewart Warner, why don't our vendors consider carrying that same one as an alternative to the OEM style, for the CASO in all of us?
              Just a suggestion, so that the Stude vendors don't lose out on the sale.
              [img=left]http://simps.us/studebaker/misc/images/Avacar-hcsdc.gif[/img=left]
              Paul Simpson
              "DilloCrafter"
              1955 1/2 Ton Pickup
              The Red-Headed Amazon
              Deep in the heart of Texas
              Paul Simpson
              "DilloCrafter"
              1955 1/2 Ton Pickup
