pertronix installation
  • pertronix installation
    I have a 64 Daytona convertible with a 289 in it. I have just purchased a pertronix kit for the distributor. Will I have problem with clearance on the wiper motor when trying to remove the distributor? It looks like the motor could be in the way and that I may have to move it? I have the Delco window distribotor What say you? Thanks John
    I don't think so, I put a delco window in my 64 daytona and I got it in there without taking anything else off.
      It will be tight with the Delco Window Dist. but with the Cap and Rotor removed it WILL come out. If not, you need to check the Front and Rear Engine Mounts if they are shot or loose the engine could have slipped back.
        The distributor should come out of the block with no problems. You'll have to wiggle it around a bit though because of the long oil pump drive shaft. Bud
          Thanks for the info on the distributor and the Pertronix setup. I will attemp this weekend. John
            Depending on where to live, you might think about sending you dist. to Bud in the LA area. he has a Sun Dist. machine and KNOWS how to use it.
            Jim
            their Memorials!
              Jim
              Who's Bud? I've got a couple of dists that could use clocking.
              Clark in San Diego
              '63 F2/Lark Standard
              www.studebakersandiego.com
                Here is the post you want for that info Clark:
                http://forum.studebakerdriversclub.c...TOPIC_ID=27878
                You only needed to look three posts above yours, on this topic! Lol!
                  Right on, Rich! Thanks for the pointer!
                  Clark in San Diego
