1950 3 speed manual
  • 1950 3 speed manual
    Our 1950 doesn't shift smoothly into second if you are going faster than 12 to 15 Miles per hour. The synchro doesn't match the gear speed. The shift from second to high is good at all speeds. Down shifting from high to second at speeds above 15 also causes the "gear grind" sound. Does anyone have any experience with this problem? Is it the synchro slider or second gear itself? Or both? Where can I get parts? Thanks, Denny
    It could be both. Probably have to take it apart to know for sure. My guess would be the synchro. Before you take it apart you might try changing the trans oil. I use 30w non detergent oil mixed one quart oil to one bottle of STP. Hope this helps and welcome to the Forum![8D]
      For what its worth.
      I put Amsoil 90w in my 3 speed and it shifts like a new car. I feel it was definitely worth the expense. I also put the same stuff in the rearend.
      Good luck
      Tim
      Tim Porter
      Hebron Illinois
      1950 Champion 2dr
        I can remember driving a Studebaker that didn't have first/second synchro. In fact, I don't think my Rockne has any at all.
        Does anyone recall when these improvements were added?
        Brad Johnson
        33 Rockne 10
        51 Commander Starlight
        53 Commander Starlight
