R2 Fuel pump ideas
  • Fuel System: R2 Fuel pump ideas
    My R2 fuel pump finally bit the big one and is dead. I guess I have two choices rebuild or replace. I know Fairborn is using high flo Mopars to replace the now non-existent R series pumps. I put on one my R1 but had to but a regulator on as it had too much pressure. So wondering what others have done - electric or ?
    Dan White
    64 R1 GT
    64 R2 GT
    58 C Cab
    57 Broadmoor (Marvin)
    Why not just rebuild it? Then & Now Automotive has good kits that are ethanol resistant, or Dave Theibault rebuilds them also I believe.
    Paul
    Winston-Salem, NC
      Try to rebuild it,I had my r2 go bad so I bought a replacement from one of our vendors and it now starves for fuel. I believe the arm is bent to much because I have a flow through electric pump that I have to turn on when pulling a long hill. Normal driving it works fine. Try to rebuild yourself first.
        StudeRich commented
        Editing a comment
        You need to specify WHICH "Replacement" Pump you got, a Real Carter modified from a Mopar or a Standard Pump (,Airtex junk) ?
        There should be No problems with a Carter, Did you return it?.
      The box says carter,# are 1557015 and FPU008.
      269.00 dollars . R2,R3 punp
        StudeRich commented
        Editing a comment
        Return it if the pressure is Low. but it MUST have a working "Reference Line" to the Blower from the Top of the Fuel Pump and also the Pump VENT must be Sealed.
