I bought a new late model 259 crankshaft from Wisc. Stude some time back, and I'm now about ready to install it. When I opened the box, however, I found surface corrosion on some of the throws. I used a rag and various soaps to clean it up, then followed that with sanding the throws with crocus cloth, as I remember reading about some 35 or so years ago in one of D. Datson's publications. All went well, except there's an area or two just in front of the rear crank flange, where the brummer seal lip will make contact, that the corrosion has not come off yet. Crocus cloth is not aggressive enough.
So, here's the question: Is it OK for me to use sandpaper, say 400 or 600 grit, on this machined surface to try to continue my attack on this corrosion? I know it'll leave sanding marks. but I am afraid the corrosion spots, that you can actually feel with your fingernail. will cause the brummer seal to leak in short order.
As always, I appreciate your replies.
Thanks,
Larry
Thanks,
Larry
