I have a tank witha few 1/4" holes on top. What kind of patch should be used to repair it.
Gas tank holes
Your tank sounds too far gone to salvage.
They make a compound for this that dealerships use is called metal patching compound is comes in a grey stick and one on its main uses is filling gas tank holes. you cut a piece off work it for a few minutes and put int over the holes and it get as hard as metal and its fully sandable.
Ryan
As Dwain indicated, soldering is a good bet. If you have the tank cooked there would be no fumes left and it could be welded or brazed.
A friend of mine had a tank from a '37 CE that was missing most of its top half. He cut a piece of sheetmetal and basically replaced the whole top half. No one will ever see it and it works fine.
Whatever repair you do, it's a good idea to have the inside sealed.
Thirty years ago we could chuck a tank that had a pin hole. Today they are too scarce to not be frugal.
Brad Johnson
'33 Rockne 10,
'51 Commander Starlight,
'56 Sky Hawk
I had a 1971 MGB with the same problem back in 1989. I sanded the top down to bare metal then laid fiberglass on top. When that was dry I used some of Bill Hirsch's fuel tank sealer. To this day it still holds!! Try using fiberglass and the tank sealer.
Laisez le bon temps roulez avec un StudebakerLaisez le bon temps roulez avec un Studebaker
I know a guy who fixed a tank once, using POR-15 and fiberglass cloth. He told me that POR-15 is impervious to gasoline once it hardens. While he had the tank out, he sanded the whole thing down to bare metal, and then covered the whole thing with the fiberglass cloth and POR-15. He said that it would prevent any future leaks as well. He then painted the whole thing. Looked really nice. I know he drove the car for several years until he sold it, and he never had a problem with it.
Hey guys, do your research!!
Check out www.gastankRENU.com they are professional tank restorers and can fix almost anything that may be wrong with a tank. They are worldwide with 50 plus agencies doing tanks, with over a million done in the past 23 years!!
Regards
I just had my 57 GH tank done by Moyers Gas Tank Renu in Greensburg, PA, and they did one fantastic job. My tank was covered in grime, and the inside had gas tar, about an inch thick, coating the bottom. They cleaned it inside and out, sealed the inside, and repainted the whole exterior in some type of thick black coating. It looked like a brand new tank. One heck of a job for $250. Really nice people too. I would recommend them to anyone.
Here's a brief from the central Indiana Gas Tank Renu franchise holder, Max Merritt:
http://www.maxmerrittauto.com/showpa...howitworks.htm
Max's Gas Tank Renu did the tank for my 1956 Packard Clipper several years ago. Nice work. Interesting to go to their shop, too, and see all the odd-ball tanks they have sitting around awaiting repair. They had a late-1950s Ford station wagon tank with a really weird shape.BP
Ayn Rand: "You can avoid reality, but you cannot avoid the consequences of avoiding reality."
