On my supercharger, right at the bottom of the outlet where the air hose runs from the supercharger to the carb box, there is a small brass tube. Looks like it may be for a vacuum line or something. What is it for, and where is it supposed to connect to?
Supercharger question
quote:Originally posted by Mike
It's usually used for the fuel pump boost referance. It connects to the back side of the fuel pump diaphragm, and makes the fuel pressure increase with boost.
Mike M.
There should be a third tube on the opposite side of the diagphragm on the fuel pump which the reference line connects to.
[img=left]http://i158.photobucket.com/albums/t102/PlainBrownR2/My%201950%202r5%20Studebaker%20Pickup%20with%20turbocharger/P1000137-1.jpg[/img=left][img=left]http://i158.photobucket.com/albums/t102/PlainBrownR2/My%201950%202r5%20Studebaker%20Pickup%20with%20turbocharger/P1000145-1.jpg[/img=left][IMG=right]http://i158.photobucket.com/albums/t102/PlainBrownR2/Ex%20Studebaker%20Plant%20Locomotive/P1000578-1.jpg[/IMG=right]
[IMG=right]http://i158.photobucket.com/albums/t102/PlainBrownR2/My%201964%20Studebaker%20Commander%20R2/P1010168.jpg[/IMG=right]
Jerry, here is a link to a post that about half way down the page, has a Richard Quinn Collection factory photo of the correct Carter Fuel pump with the reference line coming out of the top of the upper half of the pump casting.
The colors are all way off with too much red, but if you look closely you will see the smaller line going up to the Supercharger. [^]
Without this line, as soon as the air box and Carb. pressure exceeds the fuel pump pressure, the fuel flows back to the pump and the engine starves.
http://forum.studebakerdriversclub.c...s=engine+colorStudeRich
The tube on my supercharger was cut off and is only about an inch long. Can this whole tube be purchased, or will I have to try and fabricate something?
quote:Originally posted by jeryst
The tube on my supercharger was cut off and is only about an inch long. Can this whole tube be purchased, or will I have to try and fabricate something?StudeRich
There's just a short hose barb on the supercharger. A couple of inches of hose connect it to the hard line to the pump. Golden Hawks used 3/16" tubing, (Avanti R2 & R3 used 1/4"). Since you only need a flare and nut on the end at the pump, you could buy a slightly longer section of brake line, and cut it from that. Do you have the fitting at the fuel pump?
Mike M.
The car is at a garage, and I noticed that he has a bunch of fittings there, so he should have one that will work.
I noticed that the small section on the supercharger swivels. Is it supposed to do that, or is there a way to tighten it?
