I started my 57 GH for the first time today. I revved it up several times, and was immeidately rewarded with a floor full of antifreeze.
Upon inspection, I could see that one of the freeze plugs in the side of the engine had blown out. Appearantly, someone had put a new plug in, and used silicone to keep it in. Either they put the wrong size plug in, or they didnt install it correctly. Obviously, it was not a tight fit, so they chose to use silicone to keep it in place.
When I look in the hole, I can see a shoulder. So now I have some questions.
1. What is the proper size freeze plug for the 289 motor?
2. Should it be the deep type, or the shallow type with no edge? The one that was in it, was the shallow saucer type.
3. Is an expandable plug better than the solid type? Will an expandable type work with the "shoulder" in the hole?
4. When the plug is put in, does the dome go toward the inside or toward the outside of the block? If the dome goes toward the outside, is it supposed to be hammered inward to get the plug to expand?
As usual, any help would be greatly appreciated.
