59 Silver Hawk 256 4brl Carter, run after rebuild
Engine cranks up idles good, revs good. When engine in hot (water flowing) the thing runs great. Turn if off, try to recrank and it wont crank. Engine turns over and over and over, tries to hit every now and then, but will not crank. Let it sit for a couple hours and it cranks right up[?]
I have a clear gas filter at the carb, and it is full of gas. I have heard of vapor lock all my life but never exerienced it. The gas line is full at the filter which is about 4 inches from the carb inlet. I always thought vapor lock was due to gas vaporizing in a too hot fuel line. The hood is still off the car and there is no excessive heat around any of the gas lines as far as I can tell.
Checked gas flow out of accel pump and flow is good. Checked spark at plugs and there is spark. Only other problem I know of right now is the generator is not functioning, but the battery is well charged.
Bottom line, it cranks cold, runs cold, runs hot but will not crank hot.
thanks for any ideas.
dell
Dell
59 Silver Hawk
64 GT Hawk
dell
Dell
59 Silver Hawk
64 GT Hawk
