How to soften rubber
  • How to soften rubber
    There was a few posts a while back on what to use to soften
    rubber anbody rember were they were at.I have a nos
    gas pedal that wont bend.
    Lenny
    Atlanta Ga.
    Try using a cleaning product containing lanolin cream such as the handcleaners used for heavy grease removal. I use one that I buy at Canadian Tire and use more of it on rubber parts and other stuff than I do on my hands. It is super for softening and cleaning the rubber weatherstrip. I scrub it into the rubber with an old toothbrush, and wipe off the residue with paper towels. A gas pedal might be too thick and hard for the lanolin absorption, but its worth a try.
    Dave D.
    '51 "Bulletnose" Champ
    '59 "Silver Hawk V8"
    Smithers, B.C. "Where a Stude in hand is worth two in the bush"
    Dave D.
    '51 "Bulletnose" Champion
    '59 "Silver Hawk" V8
      That thick rubber gas pedal may be a candidate for using silicone spray. I've used silicone spray on rubber weather stripping with success.
      sals54
      sals54
        Lenny, Paint remover will soften rubber. Use the paint remover that adhears to surfaces so that it won't run off. You might want to do some test work if the rubber is critical for survival. Don't leave the paint remover on too long or it will really soften the rubber too much, that is why I would do some testing to get an idea of how long to leave it on a surface.
          If all else fails, glycol-based (DOT3 or DOT4) brake fluid will soften rubber as well. Just don't get it near any painted surface.
            My father-in-law was chemist among other things. He said glycerine softened rubber. I don't know if you can get that any more. I had some but don't know where it is.
            Claude Chmielewski
            Studeski
            http://www.studeski.com
            Fillmore, Wisconsin
            47 M-16 Truck
            62 GT Hawk
            63 Lark
            64 Commander Wagonaire
            50 Champion Regal (parts car)
            63 GT Hawk R2
            [img=left]http://www.studeski.com/62hawk/62hawka/dakota01_250.jpg[/img=left]
            Claude Chmielewski
            Studeski
            Fillmore, Wisconsin
            47 M-16 Truck
            53 Commander Regal HT
            53 2R5
            60 Lark VIII Convertible
            60 5E7 Champ pickup
            62 5E7 Champ no box
            62 GT Hawk 4 speed
            63 Lark VI parts car
            63 GT Hawk R2 4 speed
            64 Daytona Convertible
            36 Dictator
            36 Dictator in pieces
              Stupid question (not my first!) and hopefully not too far off-topic... Why do you need to soften/bend the rubber gas pedal? Be kind with your answer to those of us who have not encountered your problem!
              Las Vegas, NV - Stop by, coffee's on!
                Caster oil- the medicine, has worked several
                times for me. But all rubber does not react
                the same. Different types???
                Tex E. Grier
                  To soften the brake pedel to instal on my 66 I put it in hot water to make it soft to slide over pedal, worked great. Doug M
                    After you mount it spray it down with STP Son of a Gun and let it soak in overnight. Wipe off any excess the next day. Keeps it soft for a long time and won't pull the oils from the rubber like some of the other rubber treatments. Spray silicon woks fairly good too.
                      The gas pedal is solid rubber no hinge,it bolts to the floor &
                      is suposed to bend when you step on it.
                      Lenny
                      Atlanta Ga.
