Four speeds for Larks
  • Four speeds for Larks
    In the same vein as my wondering about on first gear start automatics, throw out the question to gather others experiences before proceeding... I was going throught old turning wheel co-operators and other references when I began to wonder about four speed transmissions. I recall reading something somewhere about this but sometime I just forget where I saw what when.
    We all know about the T-10 that was used in the Hawks and Larks.
    What other fourspeeds can be used in a studebaker with a minimum of machining. I would love a T-10 but I do not think that I could afford one at this time.
    Jeff T.
    "I'm getting nowhere as fast as I can"
    The Replacements.
    \"I\'m getting nowhere as fast as I can\"
    The Replacements.
    Since T-10's are about the cheapest out there, you may be out of luck. A typical used T-10 is in the $300-$400 range.
    JDP
    Arnold Md.
    Studebaker On The Net
    http://stude.com
    My Ebay Items
    http://www.stude.com/EBAY/
    64 GT hawk
    64 Daytona HT
    63 R2 4 speed GT Hawk (Black)
    63 Avanti R1
    63 Daytona convert
    63 Lark 2 door
    62 Lark 2 door
    60 Hawk
    59 3E truck
    52 Starlight
    52 Starliner
    51 Commander
    JDP Maryland
      Dave T-Bow is working on a adapter for a cheap MOPAR 4 speed that has the 4th gear as a overdrive, but the bell housing will be in the $300 range.
      JDP
      Arnold Md.
      http://stude.com
      My Ebay Items
      64 GT hawk
      64 Daytona HT
      63 Avanti R1
      63 Daytona convert
      63 Lark 2 door
      62 Lark 2 door
      60 Hawk
      59 3E truck
      52 Starlight
      52 Starliner
      51 Commander
      JDP Maryland
        I once put in an early Ford TopLoader, but those usually sell for more than T10s.
        I do trust everyone knows there have been dozens of versions of the T10 over the past 50 years, only two of which bolt up to Studebaker V8s.
          Hmmmmm. maybe I can swing this. For some odd reason I thought that the othere possibilities were cheaper since there were more of them.
          Live and learn
          Jeff T.
          The Replacements.
          The Replacements.
            I think you could probably get a cast iron GM Saginaw cheaper than a T-10, but then you'd spend bucks to adapt it to the Stude bellhousing and machining an adapter for the pilot shaft...and you'd end up with a 4 speed that is weaker than the T-10 or a Muncie.
            If you are going to do the work of adapting a transmission, a 5 speed (T-5) would be a much better choice. They cost about the same as a T-10 and you'll end up with an OD 5th gear.
            More info here...
            http://www.studebakerdriversclub.com/tech_5speed.asp
            Bellingham, WA
            Bellingham, WA
              No kidding! I have two of those Mopar o/d 4 speeds in my stash, purchased with an eye toward adapting them to my Studes, got any more info?
                Talked to Dave Thibault at the Reedsville meet and actually saw a Mopar 4-speed swap he had done. It is not difficult as transmission swaps go, but it is not anywhere near easy or cheap. The main advantage is a wide-ratio all-synchro 4-speed with overdrive top gear would be good in a truck. As I remember it:
                1. You need the 5-speed truck bellhousing and throw-out bearing setup.
                2. You need the aluminum case Mopar tranny, because adapter ears have to be welded on it to bolt up to the Studebaker truck bell housing.
                3. You will have to use the Mopar clutch disk with the Studebaker pressure plate.
                Bottom line for a street-driven car, the T-5 is the better investment, unless, as you do, you have the transmission, the talent and the time.
                thnx, jv.
