my underseat{drivers} side heater fan quit running.the passenger side has not worked since i bought the car several years ago.i had the oil changer the same day the fan quit.it appears that an electrical conection could have been knocked loose.question one, where do wires connect to heater fan and are they under the carpet or under the car. i cannot see any connections above the floor line.question two, is there a fuse for the heater fan?question 3, i see only one wire coming out of the switch, is there one missing or is the fan grounded to the body?question 3 , is there a heater fan in the fender well?
cabin climatizer hawk
WHAT YEAR "Hawk" are we talking about: 1956 to 1964 ??
Question # 3 : Yes on '56-'62 Hawks, the Passenger Side Heater Fan is connected to the Fender Door Air Duct inside the Right Fender.
There is Only One Wire on any single speed Motor or ANY electrical devices, as ALL of them are Grounded to the Battery (-) through the Body, Frame and Engine.
The Defroster Fan Motor and Heater Fan Motor run at Two Speeds accomplished by a "slow-down" Resistor for Low speed on the Switch.
Your Left Side Heater is a Optional Accessory rarely ordered for Extreme Climates, it's Fan will be under the Floor with the Heater Core.
The Fuses are mostly all on the Switches or in line on the Wire like the Radio, but Headlights use a Circuit Breaker.
You can always find where a Wire goes, by following it or looking for it's matching Color Coded Wire where you "Think" it should go.
If in doubt, use a Test Light to find out.Last edited by StudeRich; 01-24-2023, 01:51 PM.StudeRich
