Picked up a questionable supercharger yesterday, open the back cover and found the impeller section had a corroded impeller. I wondered if there was more corrosion damage that would make the McCulloch unrebuildable.
I wanted to open up the body to check for issues. pulled the outer pulley half, but could not get the sliding rear half to budge, decided to go in from the rear. Learned how to pull the impeller from a call to Phil Harris. Pulled the impeller, pulled body bolts , rubber hammered the body apart and found no corrosion!
But surprised to find mud dabbers in the body casting slots.
So the question is - How do I install this supercharger on my 1955 Commander Ultra Vista Regal new rebuilt 259 V8 , 6 volt +grnd?
Seems I need to
add correct SC pulley on crankshaft.
Install the 57 Hawk SC mount casting to the thermo outlet.
install the 57 Hawk intake manifold, carb, air chamber, and a suitable air cleaner.
add a 1" spacer to fan to move forward.
add fuel pump pressure line from pump to air chamber.
Maybe other issues?
Last time you had a stuck inner pulley half, how did you resolve the issue?
Seems I need to
Maybe other issues?
