I had my headliner done and I’m not confident in the current position of my sunvisor clip position. Would another 1963 GT Hawk owner measure the location of the sunvisor clip location. Maybe one measurement from the sunvisor mounting screw to the clip screw location and another measurement from the inside rear view mirror screw to the clip screw placement would be great.
Sunvisor Clip position
Originally posted by jackb View PostAFAIK - there is only 1 screw hole to mount the clip. Can you telegraph out your visor pin ?
No, my pins have been glued in by a previous owner. As soon as I get the measurement I can install the sunvisor clip and then I will drill out the visor balls and insert new.
Rather than re-inventing the wheel I thought it would be beneficial to have the original measurements to get it right!1963 Studebaker GT Hawk R1 63V-33867
1964 Studebaker Avanti R1 R-5364
1970 Avanti II RQA-0385
1981 Avanti II RQB-3304
Are the "Pins" you refer to the short Rod with the Ball?
They SHOULD just twist and Pull right out, unless that is what is Glued in.
Former Owners....
Originally posted by StudeRich View PostAre the "Pins" you refer to the short Rod with the Ball?
Former Owners....
Thanks
Robert1963 Studebaker GT Hawk R1 63V-33867
I can't believe it's been three days and nobody posted pics for you. I took the exact pics you're asking for years ago to answer the same question for Topper 2011 . I tried to find them three days ago but couldn't find them among the thousands I have on this machine. Perhaps Topper still has them and will chime in. I'll try to remember to take some new ones tomorrow to post, but my memory isn't what it use to be.
Apologies Robert. I've been asleep at the wheel. Here are the measurements from Rick when I needed the same as you. BTW, your headliner turned out way better than mine.
I also have to advise you that my 62 had different visor arms than the ones I replaced them with. So, I had to drill new holes. My arms were direct 90 degrees while the replacement ones are like yours, kind of a dip at the 90 instead. It was enough to throw off the length for me. I used a small drill bit (from when I was into HO trains) and holder to poke through the perforations to find the original holes. Rick, I just noticed you have a cracked clip."Man plans, God laughs".
Anon
- Likes 1
Rick, Anon, I really appreciate the pictures. Now I can be sure all is placed properly.
Anon, What issues did you have with your new head liner?
Thanks Again Everyone
Robert
Originally posted by 1inxs View PostRick, Anon, I really appreciate the pictures. Now I can be sure all is placed properly.
Robert
I have tucked it in a bit better since this photo, but it still looks like a rumpled suit."Man plans, God laughs".
Anon
- Likes 1
Considering what you started with I think the whole car looks great Roland! Good catch, I never noticed the crack, then again I never use the visors so have never had a need to move them out of the clips. It actually looks like both clips have a crack in the same place.
- Likes 1
Did you purchase a pre made liner or get one sewed up? Did you pull the rear glass? I know it helps to get the headliner positioned better. A few wrinkles and rumples aren’t so bad considering the alternative. It was kind of funny. Before I got the new head liner, people would never notice anything wrong until I asked them to turn around and look in the back. It was duck taped and looked really bad.I removed the windshield since it was broken anyway and wanted new weatherstrips, I hate water leaks.
The rear glass was pretty easy.
Anon
It looks pretty good. Hopefully a good hot summer will even things out.1963 Studebaker GT Hawk R1 63V-33867
