I really don't want to go any larger. If anyone out there might have any leads on 20mil over piston rings, could you pease let me know. (I figured this might be one of the tougher aspects of this project). 10 over won't do it because some of the cylinders just are too scratched. I really appreciate any and all help any of you out there is Studeland may have to offer. Thanks in advance for your help.
Looking for 20 over cast iron piston rings for 1955 President 259V8
Russ at studebakerparts.com shows them on his site. http://www.studebakerparts.com/stude...tore/s/engine8Tom Senecal Not enough money or years to build all of the Studebakers that I think I can.
Originally posted by cwsimpson View PostI really don't want to go any larger. If anyone out there might have any leads on 20mil over piston rings, could you pease let me know. (I figured this might be one of the tougher aspects of this project). 10 over won't do it because some of the cylinders just are too scratched. I really appreciate any and all help any of you out there is Studeland may have to offer. Thanks in advance for your help.
1. This is likely the last rebuild this Studebaker will ever need or get.
2. The difference between .020" and .030" is structurally insignificant.
3. Even at .030", the cylinders can theoretically be rebored at least two and some three times more.
jack vines
Thanks Guys-
(tsenecal, Jack & Eddie)
ts-I did recheck with Russ.- He does have 20 over in chrome- just not in cast iron. (I checked with him earlier in the year also)Thanks for responding Eddie and Jack. Respect your opinions on this very much. I think I'd rather stick with the cast iron here- I don't have any experience with chrome. The 030 rebore- I'm sure you're both right- I'll discuss this with my machinist. Again- thx all. Any and all opinions and data welcome.
Chuck S.
thx enje-It seems like a lot of places list these but they are definitely in short supply. The typical response when calling is "I haven't seen those for 6 mos. or so." I guess I was just hoping that someone might have a set somewhere. but 30 over will do just fine. Thanks
Jack- Thx for the heads up on the Hastings rings
I anticipate a bunch of filing (and very careful deburring) to get the proper end gaps on 24 rings. The finished gap has to be no tighter than the minimum in the smallest part of the bore.
After I filed the first one I'd out it in my smallest bore and check with a bright flashlight for light between the ring OD face and cylinder. If there is light the chances of the ring conforming in service is questionable.
Might be able to do the "light test" by overlapping an uncut ring's ends and installing it in the small cylinder. No need ruining a new ring set for nothin' .
Oh, and if the new ring side clearance in the piston groove is much over .003" performance and life may be unsatisfactory.
As Jack V. has said several times: the COST; Parts, Effort, Labor etc. of doing a "Patch up" Job is way Too close to the cost of a "Right Thing" Job, to even Think about it.StudeRich
- Likes 1
If it helps Chevy 194 6-cylinder engines use the same rings, although you would have to buy 2 sets to have enough for 8 pistons. Also, have you tried Ebay? They often have NOS and Vintage aftermarket sets available. Good luck to you.
JoeLast edited by irish; 12-14-2022, 07:17 PM.sigpic
1962 Daytona
1964 Cruiser
And a few others
Originally posted by irish View PostIf it helps Chevy 194 6-cylinder engines use the same rings, although you would have to buy 2 sets to have enough for 8 pistons. Good luck to you.
Joe
jack vinesPackardV8
The last time I couldn't find rings, I measured the old ones and called Hastings. They came up with rings that all I had to do was set the ring gap. That motor has been running great for over 50K miles since then, and I don't treat it 'nice', I run the hell out of it.
Originally posted by yeroldad View PostThe last time I couldn't find rings, I measured the old ones and called Hastings. They came up with rings that all I had to do was set the ring gap. That motor has been running great for over 50K miles since then, and I don't treat it 'nice', I run the hell out of it.
jack vines
