Most of the online descriptions/instructions for C/K headliner installation (Ray-Lin, one on Bob Johnstone’s) make no mention of using any staples, or even the presence of the tack strip. So what’s the consensus? Yes or no? If required, does anyone have any pictures of where the tack strips go? Also, is there a more proper name for them?
53 Coupe vinyl headliner—tack strip: yes or no?
I know there are tack strips around the back window and portions of the rear quarter windows. Been almost twenty years since I did the headliner in my '53 Coupe, so my memories of elsewhere are vague at best. Should be easy enough to see when you remove the old headliner.
Some of my original cardboard tack strips were still usable, but most not. I bought the replacement vinyl tack strip from Restoration Specialties in Windber, Pa. He has a couple thicknesses available. Use the thinner one. They were originally attached to the sheet metal with screw-nails, I used tiny sheet metal screws.Brad Johnson,
'56 Sky Hawk in process
My '54 sedan had tack strips, but I don't know for sure if the C/K cars used them in '53/'54.
Above the side windows, there is a curved aluminum tack strip that starts by the windshield and curves slightly behind the rear of the main side window. It has sharp angled teeth that hold the headliner up between the strip itself and the top of the side door opening.
Just ahead of the rear fold out window, there is a filler strip that starts at the end of the aluminum tack strip and goes down to the door panel.
Front and rear are glued, preferably with the windows out.
In the way back, I bought headliners from Acme Headliner, in LA, Ca. Most of them were a good fit, but, on occasion I had to send one back for exchange, but rarely. They have been in business for about 100 years and have patterns for virtually every vehicle American made.
Originally posted by Jeffry Cassel View PostIt is glued. I do not recall any tack strips on these cars. Measure carefully and go slowly. Invest in a good headliner tho I have no idea who makes a good on anymore. Can anyone recommend a good source since I too will need one soon?
Originally posted by rockne10 View PostI know there are tack strips around the back window and portions of the rear quarter windows. Been almost twenty years since I did the headliner in my '53 Coupe, so my memories of elsewhere are vague at best. Should be easy enough to see when you remove the old headliner.
Originally posted by 55s View PostAbove the side windows, there is a curved aluminum tack strip that starts by the windshield and curves slightly behind the rear of the main side window. It has sharp angled teeth that hold the headliner up between the strip itself and the top of the side door opening.
I got mine for a 1960 Hawk from Automotive Interiors. It fit well and didn't take too long to get. http://www.automotiveinteriors.com/P...hl-pass-1955-vTom Senecal Not enough money or years to build all of the Studebakers that I think I can.
