So I have discovered a reduction gear starter that works with my modified 289 V8 standard shift, 162 tooth flywheel. It is composed of an existing motor and solenoid (Denso?), and a 9 tooth gear. They machine the aluminum mount/adapter. At first I had problems with engagement of the starter gear and the flywheel, so they machined a 5/8" spacer that positions the gear into the correct position. The outfit is "Snap Rebuilders" in Salt Lake City. It is expensive, $350. They advertise a starter on their website as being for the "56 Skyhawk", but that is not the right starter, they assemble the correct unit separately. Check to see if they intend to incorporate the spacer into the starter. The fellow I worked with is LaVerl.
Stude V8 reduction gear starter
Electrical: Stude V8 reduction gear starter
Toby Knoll Garage
www.tobyknollgarage.com
______
'51 Muntz Jet
'53 Woodill Wildfire/Dodge
'54 Hudson Hornet Grand National Tribute car
'55 Studebaker Speedster/Cadillac
'56 Corvette SR replica
Tags: None
Originally posted by PackardV8 View Post
Smaller and lighter, mainly.
jack vinesToby Knoll Garage
______
'51 Muntz Jet
