My setup works great. I have no baffle under the block off plate, I have a hose from it to a tee between the valley pan and PCV in the manifold. I have no added oil consumption. Yes, I use to have a AFR meter in each cylinder bank, I currently only have one, because I ran out of places to mount gauges and wanted to add a different gauge. I only have room for eleven gauges.
PCV conversion
Originally posted by Hawk GT SS View PostFor what it's worth. (link below)
Originally posted by bensherb View PostMy setup works great. I have no baffle under the block off plate, I have a hose from it to a tee between the valley pan and PCV in the manifold. I have no added oil consumption. Yes, I use to have a AFR meter in each cylinder bank, I currently only have one, because I ran out of places to mount gauges and wanted to add a different gauge. I only have room for eleven gauges.
I'm interested in the AFR setup you use. Do you still have the sensors for each bank? What brand of sensor, and do you like them? What brand of gauge do you use for the AFR? Have you thought of a switch to use the same gauge, but to read each bank at will? This is often done for oil temp for different locations.
Thanks
I hadn't thought of switching O2 sensors in order to use the same meter. I only had the two so I could read them simultaneously, they read so very close to one another most of the time, I figured having both was redundant. If I remember right the sensors I used were Subaru wide band units. I don't remember a brand on the meters but they were cheap seven years ago, around $35 each. They're basically just voltmeters with a display logic conversion to read as AFR.
Originally posted by bensherb View PostI hadn't thought of switching O2 sensors in order to use the same meter. I only had the two so I could read them simultaneously, they read so very close to one another most of the time, I figured having both was redundant. If I remember right the sensors I used were Subaru wide band units. I don't remember a brand on the meters but they were cheap seven years ago, around $35 each. They're basically just voltmeters with a display logic conversion to read as AFR.
Just looking at some of the posts I've made on the other PCV thread, for 170ci, and I have used a manifold port for a PCV, but that was on an OHV 6 and therefore; it was centered in the manifold, just under the carb. So, I'm not against the idea of using a manifold port, just would like to use the best location that is available, to my understanding.
