Hello everybody-
I decided to start on something "simple" to fix on my recently purchased 63 Hawk, and chose to go after the non-working fender lamps. The old plastic inserts were intact but yellowed and cracked, and of course did not light up as designed. What I found when I got both sides disassembled was similar to others' experience -
http://forum.studebakerdriversclub.c...=fender,lights
- heavy corrosion of the light sockets (along with the plastic insert epoxied to the moulding on one side
, and missing gaskets). However, there was voltage at both sockets if I tested against a good ground. These assemblies consist of a light bulb socket attached to a 90-deg angle bracket which screws into the fender molding, with a long cable back to a connector.
The issue appears to be that whatever means were used to attach the bracket to the socket has gone non-conducting over the years, so there's no path to ground. When I removed some of the corrosion from a socket and provided a good ground, the bulbs would light up - even the old ones (with matching patina
). So I soldered a bit of wire to the shiny spot of one socket and wrapped the other end of the wire to the screw in hopes that mounting all this back onto the fender would yield a workable ground. However, there was no joy resulting. I expect that now I will have to run ground wires out with the 12v leads and find some solid place to ground to.
The Stude part # for the socket and cable is 1353741, and as near as I and the Internet can tell are made of unobtainium. Although mine appear to still be conducting at least to the sockets, does anybody have a source?
Thanks in advance-
Jim K.
63 Hawk
Thanks in advance-
Jim K.
63 Hawk
