Does anyone have any tricks for reducing fuel staining or seepage at the air horn gaskets? The gasket pair were tightened to spec. and retightened after a good heatup, but after a few thousand miles the fuel stains show a trickle-down appearance at several locations around the perimeter. I'm planning on regasketing with a pair of Edelbrock gaskets. Any thoughts?
R2 Air Horn Gasket
Some of the air horn screws are supposed to have "Permetex" on the threads when you put it together. See the manual.
As you mention, two gaskets are used. Can you verify that the Edelbrock gaskets are an exact match? They are available in packs of five - just the air horn gaskets. I haven't taken mine apart yet to check. Mine looks like it has "Permetex" on the gaskets, too. It still seeps a little; when it has gas in it...
Mike M.
Mike, the Edelbrock gaskets seem to be a good match with all the critical holes or openings in the correct locations. I will try treating the gaskets to make them more "wickproof" but haven't decided on the treating material yet. I was hoping someone had already tried a few things, but I guess not. Soft copper might be a good bet for an alternate material but would be tricky to make.
