Just bought a '53 Champion Starlight. Previous owner said the clutch friction point was JUST off of the floor - which was ok with him due to a bum hip!
l went to my old-car mechanic and asked to have it re-adjusted properly so that the friction point is higher. (When the car is driven for over a half hour and fully warmed up, it is difficult to put it in first gear without grinding. Putting it into 2nd gear first, or shifting into first before the car is FULLY stopped will do the trick, though.)
The mechanic came back to me saying that he could only adjust it a VERY small amount since the adjusting rod was already out of threads to turn it further. He would have to remove the rod and run a die over it to create more threads and then make a further adjustment! Meanwhile the friction point is still JUST off of the floor and the pedal has about 3 inches of freeplay!
Something is wrong here! Is he adjusting it in the right direction? The parts book shows a different rod for sedans vs. coupes/hardtops - do l have the wrong one installed on my car?
Any thoughts? l need some direction!
Thanks.
Thanks.
