66 Daytona
  • #16
    I replaced my damaged carrier my 62 GT with Auburn unit similar to this one. I paid around $340 for it a couple years back.
    https://www.4wheelparts.com/p/auburn...R-BGQT-5420112
    Not sure if it fits a 66 Daytona.
    "Man plans, God laughs".
    Anon
    • #17
      It looks like the 9 inch I’m looking at is 8 inches wider I am trying to figure out the best way of going apon this
      • #18
        I also have a gm 10 bolt that is 373 with alburn pozi but I will have to put spring plates on. Might be my path
        • #19
          The GM will likely have a 5x5 bolt circle, not the 5x4.5 you need. You can have the 9" shortened. It is often done.
          78 Avanti RQB 2792
          64 Avanti R1 R5408
          63 Avanti R1 R4551
          63 Avanti R1 R2281
          62 GT Hawk V15949
          56 GH 6032504
          56 GH 6032588
          55 Speedster 7160047
          55 Speedster 7165279
          • #20
            I can purchase adapters or use universal wheels which I have a set that might work. And I have a feeling it may have slicks on it soon so I’m not too worried about the bolt pattern
            • #21
              Check out this page about Ford 8.8 rearend.
              Ford 8.8-Inch Rear Axle History & Specs - The Ranger Station
              • #22
                So nibbling along the edge of this I conclude my 54 commander has a 44 in it?
                • StudeRich
                  StudeRich commented
                  Editing a comment
                  None of this talk here about a '66 Daytona with Flanged Axles has ANYTHING to do with a '54 Commander.
                  However anyone who has a Pre-1959 Studebaker V8, Commander or President, that is still Original, WILL have a Dana Model 44 Rear Axle.
              • #23
                You have a Dana 27 with 3:07 gears, if you decide not to use it, I would like to have it. A Dana 44 from another Studebaker would be the easiest swap, it's much stronger than the Dana 27 you have and it has less parasitic drag than a Ford 9 inch, which is probably more than you need anyway. What gear ratio are you wanting to use?
                Best of luck,
                Joe
                1962 Daytona
                1964 Cruiser
                And a few others
