thanks bob-i'll give you a call next week. from what everyone is saying i think i just want to get rid of those ii's entirely
they just keep following me home
66 cruiser replacement brake drums needed
Blue have you tried Studebakers West in Redwood City? They might have something, I live in Castro Valley and have a nice 66 cruiser parts car engine and trans are gone along with the seats and door panels, you will never see floor pans and nice and new looking as these, I don't think it has the large drums on it in the rear but will look and see, you can call me any time on my cell 510-266-2522.....Bob
its definately 11 inch drums on the car-flanged. the 66 cruiser was a power brake car too if i recall. it sat untouched at gilleys in placerville for years, aside from someone removing the chevy frame mounts.
i got the hood and grilles at a swap meet in Sacramento, the hood supposedly came from cole cutlers bonneville car-it is reinforced down the center, and has no way to put the stock latch assembly on. I like it because it is the only hint to the uninitiated that it is not just a champion six-although the exhaust should warn people also. I basically was going for a "what if a moonshine runner ran a Studebaker" look
Very SHARP looking car Blue. I like the results of your front end changes and the hood safety pins.
Middle TN Show in Shelbyville TN April 4th 2009
Richard Burks
Middle TN
53s
57 Transtar
Blue are you sure that you have a flanged axle? not all 65 and 66 cars came with one and this late in time anyone could have changed it over because the flanged ones are hard to come by, also most brakes on the rear of disk brake cars were 10" and not 11" at least all that I have remove and believe me I have removed a few. Good luck I have only had one that I needed to cut the drum and lose the shaft.
my henry j has a straight axle, but isn't really high. i didn't want an excessive nosebleed front end. i live in the hills, and neede some kind of stability.its higher than stock, and lets you know its there, but not in your face.
I have 3 Henry Js and one of em was an old race car with a straight axle it had a front crosmember that was dropped about 9" the headlights were about 4 to 4 1/2 feet off the ground. i cut the cross member out and still have the front axle (early ford i think), I like my cars low to the ground.
clonelark
i must admit that i wish i would have kept her stock- i like the 55 sheetmetal, and the 259 ran like a top, but i made these decisions years ago- pre internet for the masses- but i had tranny problems with no resources to fix, got a deal on the sheetmetal, and had a really nice regal champion hardtop that i put the 259 into, and she gained all the parts needed to go back on the road. and i still have my first(of 18) Studebakers i've owned. as to the 327 4speed combo- no regrets once i get the rear end issue squared away, put exhaust on her, i will be ready to drive her again for the first time in 10 years.- then i get to finish the straight axle henry j
quote:Originally posted by borracho
car looks ok but you put a chevy in it? I bet you're the type to put a straight axle under a Henry J too!
Thanks for the help. here's a picture of her. I changed all the shhetmetal over years ago, to mt regret now, but i still have her. she has a 327 chev and a 4 speed now
thanks- i think i'll just transfer the 55 brakes over to the flanged axle and have the best of both worls- i was wondering about those 7/8' wheel cylinder kits i got.
yes, disc brake cars had completely different brakes than the drum brake cars. You'll need 10" drums for a flanged axle, unless the ones from your old tapered hubs can be used (not sure) and you will want to transfer the 10" backing plates etc. over from your old axle.
If you leave the "disc brake" rear brakes on the car, your brakes will actually be *front* biased - even though they're larger in diameter, they're the older, non-self-energizing brakes to compensate for the higher line pressure required for a given brake torque for the front discs. Now that's not a horrible thing; it's better that the fronts lock before the rears, but you won't get the same braking power that you would simply by using the '55 brakes. Plus, it's easier to find parts for the '55 brake setup...
55 Commander Starlight
I have an identical 66 cruiser which I have parted out and still have the whole rear end. I didn't attempt to get the brake drums off and if you exhaust all other possiblities I would get them. The car had about 65,000 miles. I sold the front disc brake set up and the rotors were still in good condition so I assume the drums will be also.
You can email at brownsl3@pie.midco.net
Steve
i pulled the complete car out of a wrecking yard in placerville about 8 years ago. it was a 66 cruiser 4 door with disc brakes and a 283 automatic. the car was all original.Are those 11 inch drums. I can put the original rearend back in, i just don't like the tapered shaft axles, as i plan to drag race the car. can i transfer the backing plate and drums off my original rear to this one?
