Turn signals & brake lights
  • Electrical: Turn signals & brake lights
    Hello gurus, before I dive into the deep end… on my 1957 Packard wagon my turn signals , brake lights and reverse lamps stopped working. I checked the fuses all ok. Any ideas where to look first? Thank you
    Lt. Col. Jimmy Doolittle
    Hi Chip,
    I am replacing the whole front harness (whenever I am allowed to return to Arizona) due to compromised wire integrity (you touch it, it breaks) and the boys at Studebaker West made the harness for me.
    Luck,
    Bill
      Because you have lost all Lights that go to the rear, it almost HAS to be the disconnects from the Steering Column to the Main Harness under Dash that have been disconnected.
      What about the Fuel Gauge, working or also Out?
        57 Packard;
        Did they all stop working at the same time?
        Question, do the front turn signals work? How about the front parking lights? Do the tail lights work.
        The back up lights (I do not believe) run through the steering column. They might run in the same wire harness to the back of the car.
        The next step would be to check for grounds and electricity at each bulb socket..
        Ron
          Thanks for the hints! . Fuel gauge, reverse lamps, stop lights , and turn signals all went out at same time.
          now I checked today I do have tail lights, license plate light, front parking lights and headlamps. I’m going to check for bad grounds and connections at bottom of steering column. May be a ground issue as dash is fiberglass.
            I do not see Grounds having anything to do with your situation, if it worked prior to it quitting.
              May be those connectors? I’ll look tomorrow.
                Well, Rich was correct! Poking around under the dash I found several bullet connectors had come apart. Presto! turn signals and brake lights have returned.! Thank you ALL!
                  You have to hear those bullet connectors "snap" just pushing isn't good enough, I also have had them come apart, some take a very hard push.
                    Just glad you were able to find the simple fix problem William.
                      Yes! You can’t imagine how good it felt just to have turn signals and brake lights again!
                      i certainly wouldn’t take the Packard out on the road without them working. So many people drive like they’re at LeMans around here these days.
