Quick Bearing Question (on front disk conversion)
  • Front Axle / Front Suspension: Quick Bearing Question (on front disk conversion)
    FINALLY buttoning up the front end and installed the new bearing races (with the proper tool), bearings and seal on the new rotors; installed right hand side and give it a spin and it just keeps going... Lovely.
    Right hand side, not so much. No noise or indication that there's a high spot but it maybe goes 2-3 revolutions before stopping (using an approximately same amount of force).
    I've taken it off several times, felt around and nothing LOOKS or FEELS amiss but am wondering if anyone has some wisdom to impart? Is this a non-issue, maybe? Should I get new bearings/races/seal and start over?
    Thanks,
    Jimbo
    -James
    The grease should stop the rotors from spinning in less than 1/2 a turn.
    You DID grease it ?
    Bez Auto Alchemy
      Thanks, bezhawk... 100%!
      I DID grease it -- packed bearings, greased races, inside of hub (thin coat) and spindle (thin coat)...
      It's seriously not supposed to spin loosely? I thought the less friction the better...
      -James
        Hey Guys,
        Would appreciate other weigh-ins on this question so I can get this thing back on the ground!!
        Rest assured, I'm not looking to waste anyone's time -- I've researched and not found a satisfactory answer so I came to the group for some help.
        -James
          Could be that I am missing something but there’s this thing called “pre-load” when installing wheel bearings. My experience is that it is one of those kind of “experience “ things mechanics develop a skill/feel for. Pre-load is the lateral force of tightening when cranking down on the castellated spindle nut. Due to variances of construction, age, etc. , counting threads (turns) or torque might not be all that’s needed. Give it your best shot, drive it some and recheck.
            I always thought you snug it up till tight, then back off to insert cotter pin.
            78 Avanti RQB 2792
            64 Avanti R1 R5408
            63 Avanti R1 R4551
            63 Avanti R1 R2281
            62 GT Hawk V15949
            56 GH 6032504
            56 GH 6032588
            55 Speedster 7160047
            55 Speedster 7165279
              Yep, that's pretty much what my experience is. I was just trying to be sure that's where the original poster is. I will admit that I have been guilty of accepting my first tightening work and failing to go back and recheck after test driving though. The other proverbial "fly in the ointment," is whether or not the brake pads are making contact with the rotors and creating a drag that could be the cause of variation between the left and right wheel rotational drag?
                Thanks Guys!
                Yeah -- I'm talking about rotor only - no calipers on (yet).
                Problem I have with left side is no amount of snugging up then backing off is giving me that "long lasting spin" I'm getting on the right side (with no in/out play)... I think I prefer as little friction as possible, yes?
                At the end of the day, I may have to bolt it up and hope for the best -- and then re-check it, of course.
                -James
                  Doesn't this Kit use the Spindle Adapter Rings that have to be heated and pressed on to adapt to the Ford Rotor?
                  My guess is, a bad one of those would do this.
                    Thanks, StudeRich --
                    Point of clarification is that yes, this is the set-up you describe -- however, it is not a new conversion (yes, new rotors, calipers, pads, bearings/races, and seal).
                    The adapter ring after cleaning up, did not show any unusual wear and the fingernail test didn't detect any grooves.
                    Previous installation had free-wheeling rotors that I am yearning for again.
                    -James
                      At that point I would probably try the right side rotor on the left and see how it spins.
                      As far as adjusting the nut, I was taught at a factory service school to seat front wheel bearings by snugging up and loosening the nut a few times while spinning the wheel. Then tighten the nut just until you are able to push the washer behind the nut up and down with a screwdriver blade. Just push gently, not twist or pry, and not so loose the washer will fall by itself. To make this work right you may have to buy one of those bearing adjusting kits with a serrated cap, thinner nut, and cotter pin. I adopted that method to all cars.
                      "Burning Bridges...Lost Forevermore"......
                        [ATTACH]n1912879[/ATTACH]
                        Thanks, Dwain and Everyone.
                        For diagnostic purposes (rotors are drilled and slotted), I will swap them this afternoon after work and report back.
                        -James
                          A drilled and slotted Rotor! That sounds like the Mustang Cobra Rotor, not the recommended by Turner Brake Rotor if using His Kit.
                            Swapped rotors: Left Rotor (LR) on Right Spindle (RS) -- about the same as when on Left Spindle. R Rotor on L Spindle: does not spin as freely as when on Right...
                            Put Right Rotor back to Right Spindle and spins like Wheel of Fortune.... Left side seems to spin a wee bit better now but I could be imagining it.
                            Kept bearings with the rotors.
                            I think my only move now is to replace the new bearing/race and seal for Left side -- unless the prevailing wisdom is to not worry about it and "send it."
                            Thoughts?
                            -James
