53 3/4 ton Milk truck engine swap
  • Engine: 53 3/4 ton Milk truck engine swap
    Will a 232 from a 53 swap into a 53 3/4 tonMilk Truck?
    Depends on what is meant by "swap". Anything is possible for someone with good fabrication skills. There are many parts, small and large, that are different on the 6 and V8. If you had access to a complete V8 parts truck, you would have all or almost all of the necessary parts to do the job without fabricating anything. These include: bell housing, motor mounts, drive shaft, clutch and throttle linkage, etc. In addition, if the milk truck was equipped with a Champion 6, the the springs and radiator would also be needed. Assume a 53 would have a K-member front frame cross section and aircraft-type shocks. If not, then more fabrication would be necessary.
    Skip Lackie
      Truck came with a six. I’m an intermediary asking for a friend.
        Plenty of room under the hood. My 52 pickup has a 259 swapped in by someone without the truck specific parts, but the factory parts make it easier and no cobbling required.
          Skip,
          Is the imput shaft on the 6 the same as on the V8? 3 spd O/D vs 4 Spd.? Clutch differences between 6 and 8? Exhaust differences?
          Bo
            Bo-
            You're right -- all those things are different, too -- at least between the V8 and Champion 6. The Commander 6 and V8 used the same input shaft and clutch. Those were just supposed to be examples, not a complete list. For example, the Champion 6 had a different Pitman arm, too -- something I found out when I put a Commander 6 in a former 3R5.
            Skip Lackie
              I think it says it ALL, if you explain to the Buyer that Pre-1954 Heavy Trucks and No Pre-1955 1/2 or 3/4 Ton Light Trucks had V8's, so it is doable just far from a "Bolt In".
              The Original "Six" is very likely a Commander "245" Flathead, plenty adequate for a Milk Truck to go 35 to 55 MPH.
