Avanti shocks
  • #16
    Originally posted by Hawklover View Post
    Bill nice to have the numbers, but........are they still being made???
    Bill where are you getting these parts numbers from.
    • #17
      IIRC, Bill was in the business for many years, including being a Koni dealer and installed them on several Studes personally.
      jack vines
      • #18
        Sam,
        Off the boxes they are packaged in.
        • #19
          Brad going to the Bilstein site proves to be a negative, no listing for the years 71-80 Camaro, so whatever you are doing as to ordering seems to be singularly beneficial to you;-)
          You have to look harder. Fronts are BSN-24-011044
          Rears are BSN-24-001564
          Summit racing
          Bez Auto Alchemy
          • #20
            Brad probably meant "1970-81" Camaro & Firebird. That is the second generation of those cars.
            • #21
              Summit racing
              Thank you!
              • #22
                I use Bilstein shocks on my cars. 71-80 Camaro. Both front and rear. Modifications to the lower mount are needed in the front, and the upper at the rear. Just press in the correct length tube and you're in business. You can't currently buy better.
                Brad just ordered 4 shocks for my Avanti............B4 they arrive would you please be specific as to what mods have to be effectuated to allow me to install same?
                many thanks in advance
                • #23
                  Too good to be true..............received e-mail that Bilsteins are back ordered in the US:-( Can I go with KYB as an alternative?
                  • #24
                    Yes - I'm running KYB gas shocks on my 83 and it rides and handles quite well. Check for numbers in Nate Nagle's notes from the club resources.
                    https://studebakerdriversclub.com/wp...nformation.pdf
                    Bob
                    Bob does the '83 have the save "A" frame as the Studes?...........I was told there is a problem with non-stock front shocks being too long, which results in cracking, then splitting of the "A" frames.
                    • #25
                      AFAIK, looks like a Lark frame to me. Just check any shocks you have against the old ones for length both extended and un-extended. Most shock companies should have that data on their websites as an initial data point.
                      No problem on mine but not a lot of miles.
                      Bob
                      • #26
                        Works great on my 1983.
