New Brakes Work Wonders
  • New Brakes Work Wonders
    Hey y'all,
    Had my Daytona's brake system completely redone a couple months ago: New shoes, lines, drums, hoses, etc. Everything but the Master Cylinder.
    Prior to that, I was getting this terrible "clunking" sound in the rearend when I would change directions (forward to reverse and vice-versa). I just knew I was going to be forking out some significant bucks for a rearend rebuild or at least have to install new universals. But since the brake rebuild... no more clunking.
    Apparently the rear brakes were binding really badly, causing the clunk as they "unstuck" themselves. I'm so releived....
    Just wanted to update ya.
    Jim's pride....
    1963 Daytona Convertible
    Cool Deal, Jim! Your speculating as to the cause sounds plausible and even moreso since it's cured with the rebuild.
    In some cases, such a noise can be from the hubs not being installed correctly and the consequent ruining of the keyways in the hub & axle.[8]
    Other things, like the looseness you feared or a bad U-joint in the driveshaft could also cause such a noise. I say all this because it would be wrong for someone reading this to make a judgement call based soley on your experience.
    Some clunking noise can even be expected (when changing direction) on cars fitted with self-adjusters.
    Miscreant adrift in
    the BerStuda Triangle!!
      Good info, Mr.B! Thanks.
      Jim's pride....
        So, when are you gonna drive that drop top over to Hazlehurst for us to see? [8D]
        ___________________________________________
        Matthew Burnette
        Hazlehurst, Georgia
        '59 Scotsman PU
        '63 Daytona HT
        http://thestudillac.blogspot.com/
          Spring will be here for ya know it.
          Jim's pride....
