I am messing with a "junk" 259 that spent several years out in the weather. Was taking all the threaded plugs out of the block today. Noted the little passage from the rear of the rearmost cam bearing, that runs up diagonally, and then dumps into the distributor tower. Am I right in assuming that its purpose is mostly to provide an escape for oil that escapes from the rear cam bearing, so as to prevent oil pressure from pushing out the can plug? I don't think this passage communicates directly with a pressurized oil gallery, does it?
And both rear water jacket plugs, and the outside plugs on the oil galleries were extremely tight. I hammered scrap nuts onto them, and stick-welded the nuts to the plugs. Wasted three nuts to get the block plug by the oil filter adapter out, but now all are out.
