1950 Commander water pump problem
  • raoul5788
    Originally posted by Studebakercenteroforegon View Post
    Maybe you got a water pump that was for theCommander Six engines when installed in 1960 Champ Pickups. That application was very specific and had the flange location very rear-ward.
    Would you know the height of those pulleys? The one from my Commander is 3 9/16". If the one you refer to is shorter then that's the issue and swapping the pulleys should fix the problem.
  • raoul5788
    I wasn't aware, good information. Thanks.
  • Studebakercenteroforegon
  • raoul5788
    Is the crank pulley supposed to be against the harmonic balancer or off like it is in the picture?
  • raoul5788
ID:	1903615 Click image for larger version
ID:	1903616 Here's the end of the shaft of the water pump and also the water pump, generator, and crank pulleys. I aligned them the best that I could. It seems the crank pulley is too far back, too.
  • raoul5788
    The pump pulley is behind the generator pulley. In fact it rubs on the body of the water pump.
  • gordr
    New water pump? If you put the pulley on it, is the belt misaligned? If that is the case, and the pump is new, return it, once you have contacted the vendor. If the belt is not misaligned, I fail to see a problem. If the belt is misaligned, you could make a spacer to bring the pulley out to the correct plane. The way to shift the flange on its shaft is to support the flange by its hub only in a hydraulic press, and then push on the end of the shaft with the ram of the press. As you can imagine, it will be tough to arrange adequate support with the body of the pump in the way.
  • raoul5788
    started a topic Cool/Heat: 1950 Commander water pump problem
    On my '50 Commander, the mounting flange for the water pump pulley is too far onto the shaft, which sticks out perhaps 3/16" past the flange. What's the best way to get the flange flush with the shaft? I've tried a gear puller but I don't want to distort the flange. A pickle fork behind the flange didn't help, either. Help!
