Engine
  • Engine: Engine
    l have a 1959 j6 hardtop lark . These two brackets confuse me which one is the correct type to be fitted? if you look at the work shop manual (lubrications) it shows the one on the car however the one unpainted came of my first 59 hardtop. What’s the difference please!
    It looks like the unpainted one is flat, so it won't work with what you have.
      Sorry if I wasn’t clear - one is being used now and the other was used on my old 59 lark but has been flattened in error but is also thicker. Just trying to make sure which thickness I need
        You might observe the bracket currently on the car when the engine is running. If the generator has any kind of vibration then maybe the thicker bracket would help prevent that. You have an example of the correct shape, so bending the flat one would be easy.
        -Dwight
          What Dwight said.
          In any case, I'd imagine that either will suit you just fine. It would take a bad imbalance to make the thinner bracket not work well.
          These cars were assembled in many locations. The use of one bracket over another would have been a common practice, when either would work the same in a given application.
            Use the thick one.
              Thanks to a All appreciate your input
