Is This The Correct Jack?
  • Other: Is This The Correct Jack?
    Hi all. This jack was in the trunk of my 62 GT. Is it the correct one? It also seems to be missing a hook piece.
    I've never owned a Gran Turismo but, many bumpers at that time had a small slot cut under the face of the bar itself that that little "hook" on your jack fits in to (I'm thinking Ford), so they would not have the "lip" you envision. It's a safer design, but not by much and, as I said, I don't know if the GT bumpers have that slot.
    If the GT does not have the slot, at least you know what to look for on other vehicles that might be missing a jack.
    Or, you could be correct and there is a part missing. The angle on that "hook" doesn't look like it would fit under a bumper.
    My guess is, I'm no help at all.
    '33 Rockne 10,
    '51 Commander Starlight,
    '56 Sky Hawk
      Illustrations of the different jack designs are in section 1812 of the 59-64 parts book. It would appear from those illustrations that you don't have the OEM 61-64 jack.
      Skip Lackie
        Thanks guys.
          The Shaft and Base are definitely ONE of the Brands and Styles Studebaker used, so the bumper attachment part may be the wrong Year.
          The '60's Car did not not have Notched Bumpers yet, they just hook under the shape of the Bumper.
          VERY many styles were used, and more than one in the same year.
          Of course I am sure most of us know NONE of them are what you would EVER actually lift your Car with, on your $850.00 to $1000.00 Chrome.
            Thanks Rich. Those bumper jacks are pretty scary to use, I have. The way the GT's rear bumper is bolted on, is flimsy at best. It is only secured on one side of the frame. I've been thinking of getting spacers between the walls of the frame and use a longer bolt to attach to both sides of the frame. I'd rather use a scissor jack instead.
              Using a Scissor, Screw or Hydraulic Bottle Type Jack and some Timber in the Trunk, if you ever have to raise the Body and Frame instead of Suspension, because of wrong offset Wheels and or Too Large a Tire Size will be MUCH Safer.
                I've got the jack that came with my '62 GT . It must be correct, I used it on the side of the freeway when the front right tire blew. It worked, but I was wondering if it would ever lift the tire off the ground. It took a good portion of its lift before the bumper stopped moving and the body began to lift. That was five years ago and I don't remember exactly what it looks like. I'll try to remember to dig it out and take some pics.
                  They are right. Hawk bumper jacks are more rare than honest politicians--and about as useful as the majority of them! I used one --once. Don't try to use it. I have bumper jacks in the trunks but I like to Carry a decent scissors jack in case I need to change a tire. A bottle jack won't raise it enough. Coming back from a meet, our Packard had a flat. It was a warm day and the jack sank into the pavement about as much as it raised the car--it was just enough tho. So a 1' x 1' piece of 3/4" plywood might be a worth while addition to the trunk stuff.
                    Ok, I finally remembered to dig out my jack and take some pics. This is the jack that came with my '62 GT. The small hook on it fits the GT bumpers perfectly.
ID:	1900949Click image for larger version
                    The foot is 6"x6".
ID:	1900951Click image for larger version
                    This is how it's all mounted in the trunk.
ID:	1900952Click image for larger version
                      Thanks Rick. The photos help a lot.
                        "Is this the correct jack?"
                        No. This is.
                        Mike Davis
                        Regional Manager, North Carolina
                        1964 Champ 8E7-122 "Stuey"
                          No. This is.
                          I thought this was a good idea.
