More Fun with '47-52 Luminescent Gauges
  • Speedo / Tach / Gauges: More Fun with '47-52 Luminescent Gauges
    Because I like the wonderful dash lighting in Studebaker's best by far, first postwar car so much, I want our car to have only the very best lights in its dash. Many years ago, I soldered up two UV LED based bulbs for just the speedometer. They were putzy to assemble as I had to bend the LEDs just right and then not mess it when they were installed into their holes.
    Thanks to 52 Commander , who by thinking outside the box, looked at pinball repair and found some interesting side discharge UV LEDs. https://www.titanpinball.com/index.p...product_id=150.
    I purchased a set but found them 1/4" too long to fit into my dash. Utilizing metal snap-in hole covers from the hardware store with gores cut into the top, the socket is moved back just enough to fit the LEDs.
    Not sure if the picture of the dash with the lights on shows it very well, but the soldered up bulbs for the speedometer is brighter than the newly purchased LEDs, but the latter are most defintely legible at night.
    Wow! That looks real nice. Good work!
    60V-L6 - 60 Lark convertible
      Wow, that's a sharp idea with a great outcome !
        That looks great! Like a Chrysler 300 dash.
          That's an idea worth saving.
            Did you remove the factory UV filters, or leave them in place?
            Would it be possible to have some more pictures on how the adapter was constructed, how the bulb socket mounts in the adapter, and how the adapter mounts in the dash?
            And could I write an even longer sentence?
              The UV filters remain in place for all of this.
              At the risk of going from too terse to too verbose, here goes a better description of the holders.
              Drill out the center of the metal snap-in cover to fit a 6-32 bolt.
              Test that the cover fits snugly into the hole in the dash. The 6-32 bolt is there to help pull it back out of the hole. Electrical ground is going back through this little piece, so each of the connections needs to be tight.
              Cut slots into the top of the cover. The sharper you can make the points, the better they will hold to the bulb socket.
              Punch the points down using something that is slightly smaller than the outside of the electrical socket in the car. Again, this needs to be tight. Bulb sockets on our car are .413" so found a socket just slightly smaller to press in the points that were cut into the top
              Press the cover over the bulb socket, insert LED and install bulb firmly into hole.
              Test, reinstall the seat and go for a test drive.
                Great work, I knew it would work. But, it would be bad form to say...."I told ya'll so na....na.....na...."
                Bez Auto Alchemy
                  A couple more points:
                  These Titan UV LEDs work with either positive or negative ground.
                  Just for fun, this morning I sliced the forward facing LED off the new UV "bulb" hoping that the bulb might go just a little further in. The forward facing LED is unecessary for lighting inside a Champion's cluster. The other 4 LEDs still work, but aren't any brighter as I had hoped.
                    Thank you!
                      Would you know if Titan Pinball has similar 12 volt bulbs?
                      Perry
                      \'50 Business Champion
                      \'50 Starlight Champion
                      \'60 Lark Convertible,
                      \'63 GT R1,
                      \'67 Triumph TR4A
                        It doesn't appear so, but if your car is 12v negative ground, I've got 4 UV LED bulbs with a BA9S base which would work. They make my dash luminesce, but that was when I found they only worked negative ground, contrary to what I'd been told.
                          Champ 51, PM sent.
                          Perry
                          \'63 GT R1,
                          \'67 Triumph TR4A
                            I noticed that most of the temperature gauge and its needle, oil pressure gauge needle, speedo needle, aren't visible in the picture; and the far ends of the speedometer are dimmer. And the ammeter needle is spotted. I know photos don't always capture things as they are to the naked eye... are those parts visible in real life?
                            Don't take this as me being critical, btw. I'm just wondering if the paint is non-responsive in those areas, or it's a limitation of the light source... or of the camera
                            Whirling dervish of misinformation.
                              Good question Lark Hunter
                              The paint has definitely failed on the speedometer and oil pressure needles and is poor on the 80, 90, & 100. RadioRoy should probably jump in here and remind me how little a Champion needs the upper range on the speedometer.
                              Pulling the new LED for the temp/oil pressure, I could see the bulb was rotated 45 degrees from ideal. Cleaning the filter with a q-tip removed a lot of dark paint chips. Those two fixes improved the lighting of those two gauges, but they are still not as good as the speedometer.
